1 1.2.36-r361 2022-09-05
2 1.2.35-r358 2022-08-30
  2. Доработка плагина Modbus.
3 1.2.35-r347 2022-08-18
4 1.2.35-r342 2022-08-16
5 1.2.35-r336 2022-08-09
6 1.2.35-r330 2022-07-15
7 1.2.35-r328 2022-07-05
8 1.2.35-r327 2022-07-05
9 1.2.34-r325 2022-06-28
10 1.2.34-r310 2022-04-25
11 1.2.34-r304 2022-04-14
12 1.2.34-r301 2022-04-11
13 1.2.34-r300 2022-04-05
14 1.2.33-r295 2022-03-31
15 1.2.33-r289 2022-03-02
16 1.2.33-r286 2022-02-11
17 1.2.33-r283 2022-02-03
18 1.2.32-r277 2022-01-25
19 1.2.31-r251 2021-12-07
