1 1.2.38-r408 2023-01-12
  1. Добавлен новый транспорт УПД.
2 1.2.37-r406 2022-12-27
3 1.2.37-r404 2022-12-01
4 1.2.36-r390 2022-10-18
5 1.2.36-r361 2022-09-05
6 1.2.35-r358 2022-08-30
  2. Доработка плагина Modbus.
7 1.2.35-r347 2022-08-18
8 1.2.35-r342 2022-08-16
9 1.2.35-r336 2022-08-09
10 1.2.35-r330 2022-07-15
11 1.2.35-r328 2022-07-05
12 1.2.35-r327 2022-07-05
13 1.2.34-r325 2022-06-28
14 1.2.34-r310 2022-04-25
15 1.2.34-r304 2022-04-14
16 1.2.34-r301 2022-04-11
17 1.2.34-r300 2022-04-05
18 1.2.33-r295 2022-03-31
19 1.2.33-r289 2022-03-02
20 1.2.33-r286 2022-02-11
21 1.2.33-r283 2022-02-03
22 1.2.32-r277 2022-01-25
23 1.2.31-r251 2021-12-07
