1 1.2.41 2023-12-12
2 1.2.39-r454 / 1.2.40 2023-10-26
2.1 Общие изменения
3 1.2.39-r452 2023-10-09
4 1.2.39-r439 2023-05-03
4.2 Среда разработки
5 1.2.39-r424 2023-04-07
6 1.2.39-r421 2023-04-07
7 1.2.38-r418 2023-03-27
8 1.2.38-r410 2023-02-22
9 1.2.38-r409 2023-01-19
10 1.2.38-r408 2023-01-12
11 1.2.37-r406 2022-12-27
12 1.2.37-r404 2022-12-01
13 1.2.36-r390 2022-10-18
14 1.2.36-r361 2022-09-05
15 1.2.35-r358 2022-08-30
  2. Доработка плагина Modbus.
16 1.2.35-r347 2022-08-18
17 1.2.35-r342 2022-08-16
18 1.2.35-r336 2022-08-09
19 1.2.35-r330 2022-07-15
20 1.2.35-r328 2022-07-05
21 1.2.35-r327 2022-07-05
22 1.2.34-r325 2022-06-28
23 1.2.34-r310 2022-04-25
24 1.2.34-r304 2022-04-14
25 1.2.34-r301 2022-04-11
26 1.2.34-r300 2022-04-05
27 1.2.33-r295 2022-03-31
28 1.2.33-r289 2022-03-02
29 1.2.33-r286 2022-02-11
30 1.2.33-r283 2022-02-03
31 1.2.32-r277 2022-01-25
32 1.2.31-r251 2021-12-07
