1 1.2.43 2023-12-29
1.1 Среда разработки
1.2 Среда исполнения
1.3 Узлы
2 1.2.42 2023-12-15
3 1.2.41 2023-12-12
4 1.2.39-r454 / 1.2.40 2023-10-26
4.1 Общие изменения
5 1.2.39-r452 2023-10-09
6 1.2.39-r439 2023-05-03
6.2 Среда разработки
7 1.2.39-r424 2023-04-07
8 1.2.39-r421 2023-04-07
9 1.2.38-r418 2023-03-27
10 1.2.38-r410 2023-02-22
11 1.2.38-r409 2023-01-19
12 1.2.38-r408 2023-01-12
13 1.2.37-r406 2022-12-27
14 1.2.37-r404 2022-12-01
15 1.2.36-r390 2022-10-18
16 1.2.36-r361 2022-09-05
17 1.2.35-r358 2022-08-30
- Доработка плагина Modbus.
18 1.2.35-r347 2022-08-18
19 1.2.35-r342 2022-08-16
20 1.2.35-r336 2022-08-09
21 1.2.35-r330 2022-07-15
22 1.2.35-r328 2022-07-05
23 1.2.35-r327 2022-07-05
24 1.2.34-r325 2022-06-28
25 1.2.34-r310 2022-04-25
26 1.2.34-r304 2022-04-14
27 1.2.34-r301 2022-04-11
28 1.2.34-r300 2022-04-05
29 1.2.33-r295 2022-03-31
30 1.2.33-r289 2022-03-02
31 1.2.33-r286 2022-02-11
32 1.2.33-r283 2022-02-03
33 1.2.32-r277 2022-01-25
34 1.2.31-r251 2021-12-07
